After upgrade to Enterasys NetSight and NAC from 4.4 to 5.1, sponsorship guest portal stopped working
Charlie_Altherr
New Contributor II
The guest gets as far as the verification screen. There he sits forever, since no code is coming. The email and txt message that are supposed to be sent are now being rejected by our email server (Exchange). It appears that NetSight is now forcing authentication of those messages. The Exchange server is set to allow these messages anonymously, and so rejects the blank password in the auth exchange. Oddly enough, this action is only happening with the guest portal. Alarm and event notifications are still being successfully sent anonymously from NetSight. WireShark traces have confirmed this behavior. Again this behavior started with the upgrade to 5.1. Does anyone have a cure? Can the email messages sent via guest portal be modified to send anonymously as they did in the past versions?
2 REPLIES 2
Brian_Townsend
Charlie,
Thank you for your inquiry. I am posting the solution for the broader audience.
After investigation, we have found that we are sending the Friendly User Name ā€œNetwork Administratorā€ as the password to the email server. As a resolution, you can clear out the message string for ā€œregistrationVerificationEmailSentFromNameā€.
This will clear out the password we are sending to the email client.
Take care
Brian
Charlie_Altherr
New Contributor II
Here are the sessions from the email traces:
NetSight Event Message Success:
220 MSECASHUB03.sauder.com Microsoft ESMTP MAIL Service ready at Thu, 29 May 2014 15:54:38 -0400
EHLO NXMGMT02.sauder.com
250-MSECASHUB03.sauder.com Hello [172.22.0.2]
250-SIZE
250-PIPELINING
250-DSN
250-ENHANCEDSTATUSCODES
250-STARTTLS
250-X-ANONYMOUSTLS
250-AUTH NTLM LOGIN
250-X-EXPS GSSAPI NTLM
250-8BITMIME
250-BINARYMIME
250-CHUNKING
250-XEXCH50
250-XRDST
250 XSHADOW
MAIL FROM:
250 2.1.0 Sender OK
RCPT TO:
250 2.1.5 Recipient OK
DATA
354 Start mail input; end with .
To: caltherr@sauder.com
Message-ID: <1454121431.2431401393279071.JavaMail.root@NXMGMT02.sauder.com>
Subject: eventType (eventSeverity) for deviceIpCtx
MIME-Version: 1.0
Content-Type: text/plain; charset=UTF8
Content-Transfer-Encoding: 7bit
NAC NetSight Guest Portal Failure
220 MSECASHUB03.sauder.com Microsoft ESMTP MAIL Service ready at Thu, 29 May 2014 15:20:44 -0400
250-SIZE
250-PIPELINING
250-DSN
250-STARTTLS
250-X-ANONYMOUSTLS
250-AUTH NTLM LOGIN
250-8BITMIME
250-BINARYMIME
250-CHUNKING
250-XEXCH50
250-XRDST
250 XSHADOW
AUTH LOGIN
334 VXNlcm5hbWU6
bmV0c2lnaHRAc2F1ZGVyLmNvbQ==
334 UGFzc3dvcmQ6
535 5.7.3 Authentication unsuccessful
