netsight_appliance_64bit.6.3.0.168.ova not work access to the Web console after installation .
Jairo_Rojas_Her
New Contributor II
I've done seven facilities in 3 different vmware appliance servers but can not open the web session and reviewing the list of ports are not available on 8080 and 8083 , 8084 .
when running on the server the command netstat -an | grep -i LISTEN sample having only few ports open , you can see the image.
c46338a6473145e0a71ad9b6700ac877_RackMultipart20151028-22603-1m0g0to-ERROR_PUERTOS_NETSIGHT_inline.jpg
13 REPLIES 13
2e2af411b9104d92bc310b2cce9eae1d_RackMultipart20151029-18887-1dlpq0m-error_netsight1_inline.png
Joseph_Burnswor
New Contributor III
The command didn't work or the command didn't fix it? I was able ro replicate the issue and it resolved it
Jairo_Rojas_Her
New Contributor II
donĀ“t work with this command.
Jairo_Rojas_Her
New Contributor II
I'll try and tell you
Thks
Joseph_Burnswor
New Contributor III
youll have to remove the break symbols out. I dont know why it keeps adding them
