Netsight Map view
Netsight Map view
dr_watson
Hi Guys,i have created a new map in netsight with Juniper MX 104 and Extreme Networks Switche.I have now the problem that I have no automatic links on my map, llpd protocoll is on.An another Problem is that I can not change the interface on my map from the router from access to interswitch.
I am find nothing in the Internet about.....
Who can help me
11 REPLIES 11
dr_watson
thx for the answer.llpd works good and i see all information i need.
The problem is that i can see on the map only links witch configuration interswitch.In some of the connection are access and i can not change it on the map or on teh router......:-(
StephanH
Valued Contributor III
Hello,
this post gives more informations according the automatic link creation.
https://community.extremenetworks.com/extreme/topics/oneview-maps-building-links-between-non-extreme...
In addition if you have still problems a workaround can be to draw the links manually.
Best regards
Stephan
Regards Stephan
