Netsight states that a device is down when its not
Tristram_Barton
Hi there, hopefully someone can help me.
I have a 460-G2 that was connected to Netsight, I had to replace the Master switch as it was having POE issues, now another switch is master but its not being seen by Netsight, stating its down, even though it show an active link.
I tried removing the stack and adding it back... Its still states that its down but now it doesn't show an active link. I've also tried removing the SNMPV3 link and adding them back with no luck.
Netsight: 7.0.6.27
Cheers
5 REPLIES 5
Drew_C
Valued Contributor III
Hi Tristram, are you still having trouble with this?
Ronald_Dvorak
Honored Contributor
Could you even reach (=ping) the switch from EMC ?
Tristram_Barton
Also SSH2 no longer works
Tristram_Barton
I've cleared all the alarms
