No syslog messages in XMC → DeviceView→ Device Logs
AntonS
Contributor II
Hy,
I cannot see syslog messages in XMC → DeviceView→ Device Logs
Although I can see the messages in /var/log/syslog
what is the correct pattern for Ubuntu x64 Appliance?
my appliance was first deployed with
netsight_appliance_64bit.5.1.0.140
uname -a
Linux netsight01.lsag.net 5.4.0-52-generic #57~18.04.1-Ubuntu SMP Thu Oct 15 14:04:49 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.5 LTS
Release:        18.04
Codename:       bionic
I already tried Ubuntu LINUX Syslog Pattern
and
Ubuntu LINUX Syslog ISO8601/RFC3339 Pattern
still not seeing anything
1 ACCEPTED SOLUTION
AntonS
Contributor II
After changing pattern to “NetSight Syslog pattern” it works
But I have some switches that have another ip for management / and syslog source.
On those devices I cannot see the syslog messages in the Device View
5 REPLIES 5
AntonS
Contributor II
AntonS
Contributor II
I can see the syslog messages in EVENTS tab
The source seems to be the problem.
Does this have to do with wrong pattern?
AntonS
Contributor II
hy,
Thank you for your answer! I did not change the user
ps -ef shows only nsftpd and mysql do not run as root user
Every other NetSight process/daemon runs as root
BR
StephanH
Valued Contributor III
Hello Anton,
if you run as different user check this:
https://extremeportal.force.com/ExtrArticleDetail?an=000093590
Regards Stephan
