Not possible to take archives from my devices
‎05-28-2019 11:39 AM
I have a failure on every switch:
Failure: 100%
reason: Management Center Archive - Error Archiving Configuration File.
See screenshot.
Failure: 100%
See screenshot.
7 REPLIES 7
‎05-29-2019 07:23 AM
Hi Sacha,
I hope that following article would be helpful for your issue:
https://gtacknowledge.extremenetworks.com/articles/Solution/ERS-switches-fail-to-archive-configuration-with-failed-to-authenticate-the-connection-error/
BR,
BR,
‎05-29-2019 07:10 AM
The switch models we use are ERS4950 (firmware: 7.6.1.033) and ERS 4850 (firmware: 5.7.0.008).
The version of Extreme Management Center: 8.1.3.65
The method that I am using: clicking right on the device select Configuration/Firmware - Backup configuration.
While busy it is saying, Management Center Archive - Executing SFTP Operation..
‎05-29-2019 01:59 AM
Hi Sacha,
We need more detail information on the issue. Which switch model are you trying to configuration backup and firmware version of the switch and XMC? Abd which file transfter method (e.g. SCP, TFTP, etc.) are you using for the backup?
BR,
BR,
