Not receiving the right trap when EAPS ring change
JohanHendrikx
Contributor II
When one link of my eaps links went down I noticed that the switch sends the trap: extremeEapsLastStatusChangeTime and there was no alarm in Netsight.
In Netsight the alarm is triggerd by extremeEapsLinkDownRingComplete.
Is this correct ?
Johan Hendrik System Architect Audax
9 REPLIES 9
StephenW
What version of code is your EAPS ring running? What kind of switches?
JohanHendrikx
Contributor II
the switch send the trap extremeEapsLastStatusChangeTime when a link of my EAPS ring goes down.
In Netsight there is an alarm (EAPS Link down complete or EAPS Port status change) that expect the trap extremeEapsLinkDownRingComplete
StephenW
Does the switch send any traps? The commands in my comment above will help you determine if it is sending traps at all.
JohanHendrikx
Contributor II
Stephen,
If xtremeEapsLinkDownRingComplete is the right trap,why don't the switch send this trap ?
StephenW
Johan, Yes, that trap it the right one. Lets make sure the switch is sending the traps first.
The "show management" command will show the snmp trap counters. You can see the counters at the bottom.
You can also use this command to send test traps.
create snmp trap severity critical event "Test" "Test Trap"
