Hi community
I am look for some advice on the interface reports in oneview.
In my Netsight (6.3) I have over 100 S series switches (Various S8,S6 and SSA's)
In one view I can generate custom reports for each infividual interface on every device/port.
If I look at the predefined reports under "Reports", we find "Interface Reports" and then we find "Top interfaces by Bandwidth".
The reports looks as follows:
The problem I have is that this reports is across all 100 switches.
I am looking for the same report but for a individual device.
I would like to see the top 10 ports on a specific S series switch.
How do you generate the same report but on a per device basis?
Regards
