07-17-2020 05:52 AM
Hello,
we have the problem that the Netsight web console with the new Microsoft Edge with Chromium does not display some objects. For example the list under "Access Control" - "Configuration" does not appear. A Java error occurred. We have no problems with Google Chrome. Do you need Java and if so, which version of Open JDK / JRE? I think it would be completely HTML5.
Many thanks for the help!
08-13-2020 07:24 PM
Hi Michael, we are working on switching to all HTML5 before Java goes out of use this December. I do not have an exact ETA for that at the moment however.
07-20-2020 06:55 AM
Hi Ryan,
thanks for your answer. I use the WebUI and have the version AdoptOpenJDK 12.0.2.10 with hotspot as Java Runtime. I see Edge Chromium as the standard browser for the future, especially in the corporate environment. Except for Netsight, I haven't seen any difference compared to Chrome. Will there be Netsight as HTML5 without Java infuture?
Thanks
Michael
07-18-2020 04:24 PM
Hello,
Per releases notes here are the supported browsers:
You shouldn’t need Java for the WebUI.
I don’t believe we support the newest Edge with Chromium browser.
Thanks
-Ryan
