Purview no application detected.
‎05-11-2016 07:08 AM
Cannot detect application on purview. "Port mirroring does not appear to be set up correctly on gre1"
5 REPLIES 5
‎06-27-2016 12:54 PM
Hi all.
please not, that if you use L2 GRE Tunnel to transmit the mirrored traffic to purview and if your gre port is an " tg.*.* " port you need to insert an 10GE optic. It will not work with an 1GE optic.
even if the tg.*.* port is up and also the tunnel interface is up. no applications are detected and no fingerprints will match.
Save some time in troubleshooting, insert an 10GE optic and reset the tunnel interface. Then you will see some applications.
‎05-16-2016 10:29 AM
Hi All,
thanks! now its working.
Marlon, can you tell us what changed in order for this to start working? It may help others reviewing the Hub. Thanks!
‎05-11-2016 08:48 AM
Also, this article may help as guidance.
https://gtacknowledge.extremenetworks.com/articles/How_To/Sample-configuration-for-Purview-appliance...
