I'm looking for XIQ Connect Feature Matrix
Hi all,I'm looking for XIQ Connect Feature Matrix.(Connect License)As many details as possible.CheersJoe
HiI've started to have an issue where rule are being process but then it carries on and process rules below and acts on these. As an example I have a 802.1x user authenticated on a port then further down the rule set I have a MAC rule with more port...
Hi, I dont want to receive infowms in xmc whenever a port starts delivering poe: I dont see the command to disable this, Can you help? Thanks.
Hi,I've got a X450-G2 switch with version 31.5.1.6 and XIQ-SE + XIQ - ExtremeControl version 21.11.11.37 and when I enforce the policy domain to the switch, I've got an error on Class of Service used for http redirect with PBR used in profile Unregis...
Hi,I'm building up my XIQ-SE deployment prior to receiving an order, I've been having a few issues and I hope someone experienced may be able to spot the cause on this one.I previously had these AAA settings being loaded to the switch when I pushed t...
| User | Count |
| 106 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
