‎10-18-2023 09:01 AM
We just purchased new 5420M switches and configured them for EXOS. When powered up the automatically joined our XIQ site and are listed as managed by XIQ. We use XIQ-Site Engine to manage our network. All of our X460-G2 and other switches appear for monitoring in XIQ but are managed by XIQ-SE. How do I remove the XIQ management and have the switches managed by XIQ-SE.
We have successfully discovered and added the 5420M switches to XIQ-SE but they show up in XIQ as managed by XIQ not XIQ-SE
Thank you,
Chris
Solved! Go to Solution.
‎10-19-2023 07:47 AM
as Ludovico_Steven mentioned the step 1 is to delete the switch from XIQ.
Step 2 is to delete the switch from Site Engine wait 2-5 minutes and add it to Site Engine again. It will update the information and consume the Pilot license from the XIQ through Site Engine
‎10-19-2023 05:26 AM
Just delete them from XIQ. If you have your XIQ-SE instance added to XIQ, the switch should then re-appear in XIQ, this time reported by XIQ-SE.
‎10-19-2023 11:28 AM
That did the trick.. Thank you.
‎10-19-2023 07:50 AM
Alternative for step two is Administration > Diagnostics > level Advanced > System > ExtremeCloud IQ Device Message details > press button "Force Onboard to ExtremeCloud IQ".
