Dear all.
I have a question about running a script during ZTP+ process.
NetSight 8.0.4.54
EXOS 22.3.1.4 Patch 4
We want to deploy ZTP+ functionality. The overall process is working fine.
Devices are discovered. Firmware is updated and the devices are integrated automaticaly to the correct site in EMC.
What I want, is that a new device gets a special basic configuration after it is discovered.
In the settings for every site in the menu "Discovered Device Actions" you can add a script.
I can add the script, but it is not executed. I did not find some detailed information in any manual about this functionality.
So can anyone help me here to get this running!?
thanks and best regards
Alex
