Capacity planning/ ports not used for some time
Is it possilble to generat a report with ports whitch are not active for some days or month ?
is the netsight capable of auto login when we use the telnet or ssh? when we right click the devices and choose telnet or ssh we need to login manually (Username and Password). is there any way to auto login using the credential we setup in cli crede...
Hello, One of our two EWC controllers is showing zero bandwidth in XMC. Historical Statistics collection is enabled for all of the interfaces on the controller. Any ideas why this is the case? Thank you much.
Hi,Currently in the process of configuring Palo Alto to authenticate with ExtremeControl via RADIUS authentication.Have everything in place, have configured the respective custom attributes to send Palo Alto once authentication has passed.At this tim...
Ho can I make a downgrade from version 8.2.4.40 to 8.2.2.100? The reason is to make a test with some bugs of the Experimental version (8.2.2.100) This is the message I got when I'm trying to install: Upgrading Application Analytics Engine from 8.2....
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
