Run XMC scripts without selecting a device
StephanH
Valued Contributor III
Hello,
in my opinion in older XMC versions (prior 8.1.3.65) there was the ability to run a script without selecting a device. But in version 8.1.3.65 I can't find this ability.
Is there a way to run the script without selecting a device? This function will be useful as well for an manual start as for an scripting task.
Best regards
Stephan
Regards Stephan
3 REPLIES 3
Stephane_Grosj1
I don't remember such capability, and to my knowledge, this is not yet possible. This is also a request we have internally, so hopefully there'll be some enhancements in this area in the future.
StephanH
Hello Stephane,
in XMC version 8.0.5.18 for example there was a checkbox to disabe the need of an device. The below. But this checkbox isn't there in 8.1.3.65
673ff8e5a5ff412fb7199c3273462ad3_RackMultipart20180801-37782-14noywk-Scripts_inline.jpg
Regards Stephan
Hi SH,
i believe this function is currently not possible because device have to be known related to Right / Varaibles etc.
I think you need a new feature this can be described in this way:
Test-Run of a Task/Script without selection of Device (for a "first" run check of the script)
This would be a good enhancement! I would use that functionality too!
