Sending flow data from a switch direct to ExtremeAnalytics (without a flowcollector engine)
Yves_Haslimann
New Contributor III
Hello everybody
I would like to configure the Extreme Switches (x440-G2, with version 22.4) to sending sflow/netflow data direct to the Extreme Analytics. I heard this is now possible without having a flowcollector enginge like PV FC-180 installed. Is this true? Because I couldn't find any referenced documentation to this. Thank you very much for your feedback.
Best regards, Yves
41 REPLIES 41
OscarK
You add the app telemetry source under flow sources.
Maybe the sflow.pol file is only created once you do a first enforce.
On the switch I think all should be configured by Analytics.
Yves_Haslimann
New Contributor III
I don't have a sflow.pol file.
And how/where can I add a "application telemetry source"?
What do I have to configure on the switch side?
Thank you
OscarK
Ok, some file editing is needed now to make it work.
On XMC, copy sflow,pol.
cp /usr/local/Extreme_Networks/NetSight/appdata/Purview/Fingerprints/sflow.pol /tftpboot/
On Analytics, edit file /opt/appid/conf/appidconfig.xml and change interfaces to be like:
Restart analytics or appid after this.
On XMC go to analytics, configuration and on your engine add an application telemetry source (the switch) and enforce.
OscarK
sflow together with a mirror config.
TestAnalytics.1 # sh sflow
SFLOW Global Configuration
Global Status: enabled
Polling interval: 60
Sampling rate: 1024
Maximum cpu sample limit: 2000
SFLOW Configured Agent IP: 10.116.3.89 Operational Agent IP: 10.116.3.89
Collectors
Collector IP 10.116.2.209, Port 6343, VR "VR-Default"
SFLOW Port Configuration
Port Status Sample-rate Subsampling Sflow-type
Config / Actual factor Ingress / Egress
1 enabled 1024 / 1024 1 enabled / disabled
2 enabled 1024 / 1024 1 enabled / disabled
TestAnalytics.2 # sh mirror
DefaultMirror (Disabled)
Description: Default Mirror Instance, created automatically
Mirror to port: -
EAN (Enabled)
Description:
Mirror to remote IP: 10.116.2.209 VR : VR-Default
From IP : 10.116.3.89 Ping check: Off
Status : Up
Mirrors defined: 2
Mirrors enabled: 1 (Maximum 4)
HW filter instances used: 0 (Maximum 128)
Hi Oskar, it's me again. Are we talking here about sflow+ ? Because my workmate said, it has to run with sflow+ and not only with sflow.
