Sending flow data from a switch direct to ExtremeAnalytics (without a flowcollector engine)
Yves_Haslimann
New Contributor III
Hello everybody
I would like to configure the Extreme Switches (x440-G2, with version 22.4) to sending sflow/netflow data direct to the Extreme Analytics. I heard this is now possible without having a flowcollector enginge like PV FC-180 installed. Is this true? Because I couldn't find any referenced documentation to this. Thank you very much for your feedback.
Best regards, Yves
41 REPLIES 41
Yves_Haslimann
New Contributor III
Hi Oskar, I have the same Analytics version running. Do you have a configuration example or a documentation of this? Thank you.
OscarK
Hello, I have made this working in my lab using Analytics 8.1.1EA2 and it is possible,. Some manual actions are needed on XMC but after that it can work. You could run into problems due to ACL limitations on the X440G2 but it can work.
