‎06-11-2024 02:30 AM
We're just in the process of building out SE and Control and have configured SE to do a backup.
I've created an SSH user with non admin access which works but when I try and open subfolders in the backup folder on SE I get access denied.
I don't really want to give my SSH account Root access so I can export these folders, is there a way round this?
What protocol works best for connecting to SE from a remote server so I can export off a copy of the SE backup?
Any help would be much appreciated.
Thanks
Jon
Solved! Go to Solution.
‎06-13-2024 06:13 AM
Thank you.
I have quickly tested this and it appears for both manually and scheduled backups the permissions on the sub-directories are set only for access by the system account. This to me is not expected.
For now it looks like only only owner privileges apply.
‎06-11-2024 05:52 AM
The NetSight sub-directory and all its children are owned by the system account, be it root or the alternative 'netsight' (if used during initial setup). The ownership of the sub-directories created for a backup have Other not set which I suspect your non-admin user falls to.
Your non-admin account needs to be a member of the group and the group that owns the backup sub-directory is "root".
Did you use the Administration -> Users -> Manage SSH Connections -> Add function to create your user or did you do it manually via CLI?
‎06-12-2024 05:35 AM
I did it through the GUI as you've said above.
Thank you.
‎06-14-2024 02:11 AM
Will this be rectified in a future version of SE so a non system owner account can export off the backups?
