Site Engine Backup Export
jonchill
We're just in the process of building out SE and Control and have configured SE to do a backup.
I've created an SSH user with non admin access which works but when I try and open subfolders in the backup folder on SE I get access denied.
I don't really want to give my SSH account Root access so I can export these folders, is there a way round this?
What protocol works best for connecting to SE from a remote server so I can export off a copy of the SE backup?
Any help would be much appreciated.
Thanks
Jon
1 ACCEPTED SOLUTION
Thank you.
I have quickly tested this and it appears for both manually and scheduled backups the permissions on the sub-directories are set only for access by the system account. This to me is not expected.
For now it looks like only only owner privileges apply.
5 REPLIES 5
That is unknown. I have put the change in behavior question to our development team pending a response. If this issue is a functional concern / something you want to see working may I suggest you open a formal case for it to be tracked.
