Stack ports (1:33 and 1:34) linkdown alarm are not cleared on NetSight
‎05-18-2017 06:55 AM
When I generate an alarm disconnecting the cable stack between the x460-g2-24t-10ge4 switches, the linkdown alarm is displayed correctly on NetSight. But when I connect the cable stack again, on the netsight the linkdown alarm is not cleared on ports 1:33 and 1:34. Do you have any suggestions? Thank you
7 REPLIES 7
‎05-23-2017 02:06 PM
Ideas?
‎05-18-2017 10:10 AM
Thanks for the help, in the screens of the traps you can notice that the traps "extremeStackingPortStatusChanged" arrive and arrive also the two linkdowns, but unfortunately do not get the traps linkups of the ports.
I also created a new "Port Stacking Up" alarm with the associated "extremeStackingPortStatusChanged" traps, which is invoked by LinkDown Clear Condition.
‎05-18-2017 08:15 AM
Hi Roberto,
Trap selection screen, can you check and confirm below option is enabled or not?
ExtremeNetworks extremeStackingPortStatusChanged .1.3.6.1.4.1.1916.1.33.4.0.3 Error
Thanks,
Suresh.B
Thanks,
Suresh.B
