Resolved! What does "In Transition" mean in the Time Since Change column
I have a flewview of Bridge Spanning Tree Information which in the column of Time Since Change shows me the legend "In Transition", do any of you know why that is?
I am running Extreme Management Center 7.0.6.27 and for some reason I cannot log into Netsight Console now. All other legacy applications work normally but during Console’s startup it hangs during this message on its startup splash screen:“Loading De...
I know what types of types you can define in <tests>.matchtype="exact", dhcptype="any" etc.It would be nice to have a documented file.I couldn't find it.==============================================================================Example===========...
Hello,I am configuring ZTP but the switch is not discovered, I have the following configuration. The switch is a X440G2-12p-10G4 model, with a version 30.5.1.15.Netsight version is 8.4.3.24. The Switch takes IP by DHCP, I contact it by ICMP and I...
Hello,I am setting up alarms to send mail with an office 365 account.I already set this parameter. But it throws me the following error.Someone of you knows why or if something similar has happened to you.Thank you.
| User | Count |
| 102 | |
| 101 | |
| 44 | |
| 19 | |
| 17 |
