Stack ports (1:33 and 1:34) linkdown alarm are not cleared on NetSight
RobArc
When I generate an alarm disconnecting the cable stack between the x460-g2-24t-10ge4 switches, the linkdown alarm is displayed correctly on NetSight. But when I connect the cable stack again, on the netsight the linkdown alarm is not cleared on ports 1:33 and 1:34. Do you have any suggestions? Thank you
7 REPLIES 7
RobArc
Ideas?
RobArc
Thanks for the help, in the screens of the traps you can notice that the traps "extremeStackingPortStatusChanged" arrive and arrive also the two linkdowns, but unfortunately do not get the traps linkups of the ports.
8e96540802cd4afc9fa3dabf13e7c0f6_RackMultipart20170518-30213-1lw2531-StackPort_inline.jpg
RobArc
I also created a new "Port Stacking Up" alarm with the associated "extremeStackingPortStatusChanged" traps, which is invoked by LinkDown Clear Condition.
a394874ba6044450969f196ae639352c_RackMultipart20170518-101870-1mlkzqw-ClearPortStacking_inline.jpg
Bharathiraja__S
Hi Roberto,
Trap selection screen, can you check and confirm below option is enabled or not?
ExtremeNetworks extremeStackingPortStatusChanged .1.3.6.1.4.1.1916.1.33.4.0.3 Error
Thanks,
Suresh.B
