Stack ports (1:33 and 1:34) linkdown alarm are not cleared on NetSight
RobArc
When I generate an alarm disconnecting the cable stack between the x460-g2-24t-10ge4 switches, the linkdown alarm is displayed correctly on NetSight. But when I connect the cable stack again, on the netsight the linkdown alarm is not cleared on ports 1:33 and 1:34. Do you have any suggestions? Thank you
7 REPLIES 7
Bharathiraja__S
Hi Roberto,
Please share the stack link up /down configuration in netsight,
As per the previous post you should be able to see link up /down traps from the switch.
Thanks,
Suresh.B
RobArc
Hi and thanks, then the traps for linkdown arrives at netsight, but the traps for the alarm cleared are not there. So to answer your question I can say that the problem is in NetSight.
Zdeněk_Pala
If you disconnect the cable you should get trap. If you establish the link, you should get the trap also. Do you receive the trap? Trying to narrow down if the issue is in management or in the switch
Regards Zdeněk Pala
