Syslog display wrong information
‎07-26-2018 05:51 AM
I have configured my switch to send messages to the syslog server (XMC).
configure syslog add :514 vr VR-Default local0
configure log target syslog :514 vr VR-Default local0 from
enable log target syslog :514 vr VR-Default local0
configure log target syslog :514 vr VR-Default local0 filter DefaultFilter severity Info
configure log target syslog :514 vr VR-Default local0 match Any
configure log target syslog :514 vr VR-Default local0 format timestamp seconds date dd-mm-yyyy event-name none tag-id tag-name
The information I see in syslog is see screencopy
I see the wrong info at source , client an the information isn't right (starts with minutes and seconds).
Johan Hendrik
System Architect
Audax
10 REPLIES 10
‎07-26-2018 10:31 AM
Logging from syslog:
How come ther is a difference in format ??
EWC:
<6>Jul 27 15:25:19 10.2.112.3(10.2.112.3) events: Radius Client Radius Response: Accepted: UserID:48:43:7C:2A:DB:3C, Client MAC:[48:43:7C:2A:DB:3C] 3
<6>Jul 27 15:25:19 10.2.112.3(10.2.112.3) events: Radius Client RADIUS server authenticated login (Access Accepted). 3
<6>Jul 27 15:25:19 10.2.112.3(10.2.112.3) dhcpd: DHCPREQUEST for 10.254.16.11 from 48:43:7c:2a:db:3c via csi6
Switch: (firm. 16.1.2.14)
<5>Jul 27 15:25:55 27-07-2018(10.2.112.209) 15:21:31 vlan.ms[1476]: Port 5 link down
<5>Jul 27 15:26:24 27-07-2018(10.2.112.209) 15:22:01 vlan.ms[1476]: Port 5 link down
<5>Jul 27 15:26:36 27-07-2018(10.2.112.209) 15:22:12 vlan.ms[1476]: Port 5 link down
Johan Hendrik
System Architect
Audax
We just finished changing hardware to G2 switches and I ve migrate XMC from windows to an apliance.
Firmware is 22.4.1.4
I don't use a syslog proxy
Messages from EWC looks oke
Johan Hendrik
System Architect
Audax
Is the issue present also for new messages comming? Do you have kind of syslog proxy/forward between your switch and XMC?
Regards
Zdeněk Pala
nop. did not help for the syslog messages that XMC receive from switches.
Johan Hendrik
System Architect
Audax
Not sure if NetSight is the right setting for your deployment. It may be Ubuntu. I am not sure if restart is required.
Regards
Zdeněk Pala
