09-14-2020 08:32 PM
Hello,
I am configuring ZTP but the switch is not discovered, I have the following configuration.
The switch is a X440G2-12p-10G4 model, with a version 30.5.1.15.
Netsight version is 8.4.3.24.
The Switch takes IP by DHCP, I contact it by ICMP and I can telnet to it but in EMC it is not discovered.
Additionally, I already validated that you are resolving extremenetwork with the Netsight IP address but I still don't see anything in the discovered tab.
How can I resolve this situation?
Solved! Go to Solution.
09-15-2020 11:25 AM
Does your Operations panel say that the devices are being discovered? If so, then check your Actions tab and make sure the “Automatically Add” option is enabled.
09-15-2020 03:35 PM
Hello,
An apology, I misspelled you you are right, the record is extremecontrol.domainname. Domain name, it already solves me like this.
Regards.
Hello Tyler,
The problem is that in the discover tab, if it shows me anything.
Regards!
09-15-2020 03:32 PM
Hello,
If I have that option enabled.
Regards!
09-15-2020 03:30 PM
Hello,
Regards.
09-15-2020 11:25 AM
