Unable to launch Netsight application
‎08-24-2016 04:35 AM
Greetings Extreme Networks,
We are a customer in Lusaka Zambia, and are getting an error below "Unable to launch application" when opening netsight.
We have rebooted the Netsight server and all services are running but to NO avail.
Any pointers?
Thanks,
Kombe
Any pointers?
Thanks,
Kombe
10 REPLIES 10
‎10-04-2016 01:41 PM
Hello,
I would suggest running through the following article to see if it resolves the issue.
https://gtacknowledge.extremenetworks.com/articles/Solution/Common-Issues-Unable-to-connect-to-NetSi...
If you are unable to connect to the NetSight server, and are still seeing OutOfMemory conditions I would recommend contacting GTAC at this point to get a case created for further investigation.
Thanks
-Ryan
Thanks
-Ryan
‎08-24-2016 07:28 AM
Hi Kombe, it's been a few weeks since the last update here and I wanted to see if you were able to resolve the problem since then.
Updated to -Xmx2048m value and restarted the Netsight service. still getting the same error.
‎08-24-2016 06:54 AM
Could you check following articles if there is any worth to check?
https://gtacknowledge.extremenetworks.com/articles/How_To/Netsight-Console-How-to-allocate-more-memo...
https://gtacknowledge.extremenetworks.com/articles/Solution/Java-memory-error-OutOfMemoryError-PermG...
