Using Facebook for NAC Login
LeoP1
Contributor
Hi Guys,
Resuming this conversation, I'm still in trouble..
I have a customer willing to enable social media authentication with NAC (ExtremeWireless 10.41.02.0014 and NAC 8.1.1.4). His TOP priority is to enable Facebook login.
I've already configured Google and Microsoft logins and both work like a charm (using L7 rules B@AP topology), but Facebook still a mess.
The L7 rules allowing Facebook (default and the custom I've created) seems not to work.
Already tried using the HTTP NAC Portal, but when it jumps to Facebook I got the HSTS problem (when enabling HTTPS redirection) or no access (if I deny HTTPS after allow L7 rules).
The only way I found is to allow all HTTPS, but this is unacceptable for the customer.
Already tried to mess with "Allowed Sites" on NAC, but I had no luck.
I'm running out of ideas (and time)... Anyone have any idea?
Thanks!
-Leo Note: This conversation was created from a reply on: Facebook login on NAC.
12 REPLIES 12
LeoP1
Contributor
Hi guys,
I was working on some tests, and I found that, by some odd reason, the L7 hostname rule for facebook.com seems to be really ignored by AP (creating other similar rules works fine).
It looks like the facebook.com is getting redirected instead of allowed...
Any ideas?
LeoP1
Contributor
Hi John,
I've already tried this config... Both L7 hostname rule on wireless controller (and creating the DNS proxy domains as L7 rules) or Allowed Domains at NAC and I got the same results.
As I said, Google and MS works perfectly, but it seems that the Controller L7 rules for Facebook (hostname facebook.com) aren't working, and it still trying to redirect (it doesn't happen with the google or MS rules).
Maybe a Controller issue? There's any way to debug it (seeing what got "allowed" and what hits the botton Redirect rule)?
Thanks!
-Leo
John_Moore
Hi Leonardo,
I believe the "Special Deployment Considerations" section in the link below has the information you're looking for in terms of which domains you must allow for Facebook Registration to function properly.
http://emc.extremenetworks.com/content/oneview/docs/control/access_control/docs/portal_config/l_ov_i...
Please let us know if that doesn't work.
Thank you,
John
