‎03-10-2025 02:02 PM
Hello, I'm trying to figure out how to setup a ztp+ workflow where the management vlan is not vlan1.
Following SE user guide, I see the following screen in page 1816 XIQ-SE user guide 24.10.10
I understand the management tag indicates a vlan holds the management ip setup in ZTP properties.
BUT when I open the same dialog in my Site engine running v24.10.13, I get something different, the management checkbox is not available, 'Captura de pantalla 2025-03-10 202428.png'
Am I doing something wrong? Is this the wrong interface, maybe the cloud UI?
regards
Solved! Go to Solution.
‎03-11-2025 02:47 PM
Hi.
configure the vlan on the site or in the vlan tab.
then go to ZTP+ Device Defaults tab and select where the management should be.
example for vlan "test" to be a management VLAN
Sincerely yours
Zdenek
‎03-12-2025 08:16 AM
Děkuji!!! 😉
found it!
Hi.
Sincerely yours
Zdenek
