Monday
Hello, I'm trying to figure out how to setup a ztp+ workflow where the management vlan is not vlan1.
Following SE user guide, I see the following screen in page 1816 XIQ-SE user guide 24.10.10
I understand the management tag indicates a vlan holds the management ip setup in ZTP properties.
BUT when I open the same dialog in my Site engine running v24.10.13, I get something different, the management checkbox is not available, 'Captura de pantalla 2025-03-10 202428.png'
Am I doing something wrong? Is this the wrong interface, maybe the cloud UI?
regards
Solved! Go to Solution.
Tuesday
Hi.
configure the vlan on the site or in the vlan tab.
then go to ZTP+ Device Defaults tab and select where the management should be.
example for vlan "test" to be a management VLAN
Sincerely yours
Zdenek
Wednesday
Děkuji!!! 😉
found it!
Tuesday
Hi.
Sincerely yours
Zdenek
