2 weeks ago - last edited 2 weeks ago
When changing the authentication type from local to ldap, i've managed to lock myself out of the graphical xiq interface :(. Is there any way of restoring the login settings to local authentication without having to perform a reinstall? I still have full access to the underlying linux system
There is a script to access the database, but i am not sure exactly what to change
Solved! Go to Solution.
2 weeks ago
Hello,
Please check out the following article:
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000078055
This has information as to where you can change the values to re-enable the failback to OS features to allow login.
Thanks
-Ryan
Many thanks Ryan.
After changing "serverAuthLDAPFailToOS" to true, i am once again able to log in as the local user.
2 weeks ago
Please see https://extreme-networks.my.site.com/ExtrArticleDetail?an=000078055 -> Unable To Login To Extreme Management Center Using OS, LDAP, RADIUS or TACACS+ Credentials
2 weeks ago
Hello,
Thanks
-Ryan
