XIQ SE 24.2.15.5 | Reports | Most Rejected End-systems Daily per mail?
03-14-2025 05:20 AM
Hello Community,
There are end-system reports such as “most rejected end-systems daily” in Control.
I have not yet found a way to export the report or even send it as a mail.
In TASKS: Scheduled Task I can select the Type= Reporting, but I cannot find the report “most rejected end-systems daily” in the selection.
How can I have this report sent automatically?
04-29-2025 06:23 AM
The issue is still relevant for us. Does anyone have any advice?
03-16-2025 01:06 PM
On GitHub: https://github.com/extremenetworks/ExtremeScripting/blob/master/XMC_XIQ-SE/oneview_workflows/xwf/NAC... you can tune it for your own purposes.
Mig
03-17-2025 07:16 AM - edited 03-17-2025 07:17 AM
Thank you very much. I have tried to import the workflow, but I get this error message:
failed to import workflow: file=NAC_report_too_many_1X_Rejects-8.5.5.30v2.xwf, unknown file format
2) Do I understand correctly that there is no way to get the original report out of the box?
