XIQ SE 24.2.15.5 | Reports | Most Rejected End-systems Daily per mail?
FL87
New Contributor II
Hello Community,
There are end-system reports such as “most rejected end-systems daily” in Control.
I have not yet found a way to export the report or even send it as a mail.
In TASKS: Scheduled Task I can select the Type= Reporting, but I cannot find the report “most rejected end-systems daily” in the selection.
How can I have this report sent automatically?
4 REPLIES 4
FL87
New Contributor II
The issue is still relevant for us. Does anyone have any advice?
Miguel-Angel_RO
Valued Contributor II
Thank you very much. I have tried to import the workflow, but I get this error message:
failed to import workflow: file=NAC_report_too_many_1X_Rejects-8.5.5.30v2.xwf, unknown file format
2) Do I understand correctly that there is no way to get the original report out of the box?
FL87
New Contributor II
We have updated to XIQ SE Version: 25.5.10.64 and still have not found a way to customize the report or send it by mail.
Can someone please help?
