XiQSE and Aruba Networks
Giuseppe_Montan
Contributor
Good evening everyone, I have to install a XiQ-se + NAC system at a
customer with various Arubanetworks 2540 and 2920 switches.
In addition to assigning them a vlan, can I create rules or policies?
Thanks in advance
Giuseppe
1 ACCEPTED SOLUTION
Bill_Handler
Contributor II
Giuseppe,
You cannot use Extreme Policy on the Aruba switches.  But you may be able to use Aruba user roles (if those models support it…) by using the Aruba RADIUS attributes within NAC.  The roles would have to be set up on the switches.
Thanks,
Bill
2 REPLIES 2
Bill_Handler
Contributor II
Giuseppe,
Thanks,
Bill
Thanks you
