XMC archive error switch has been removed
stephanos_kaish
New Contributor II
Hi all,
We have removed some switches from the Devices Tab on XMC, yet under Archives some switches are reported as File not found/Missing.
I cant understand why it would report the backup failing if the switch no longer exists and not anywhere in XMC.
Do I need to remove them manually from somewhere?
1 ACCEPTED SOLUTION
Zdeněk_Pala
Hi Stephanos.
change something in the setting (e.g. uncheck and check again) and then the save button is available for you.
Regards Zdeněk Pala
10 REPLIES 10
Zdeněk_Pala
Hi.
I see your issue and I was able to replicate it in 8.3.1.9
following worked for me: save the archive. in my case the number of devices updated from 19 to 18 and the issue is gone.
I hope it helps you.
Regards Zdeněk Pala
stephanos_kaish
New Contributor II
the switch for example with ip 192.168.103.27 is no longer in that list so cannot remove it.
stephanos_kaish
New Contributor II
Thank you but I dont have /world path and even if i create a path and add every device available in XMC, it doesn't show up in the list so it cant be removed.
Zdeněk_Pala
Uncheck the device in your archive:
Regards Zdeněk Pala
stephanos_kaish
New Contributor II
Hi Dilraj,
There is no information there to suggest where the file is stored.
Im not sure you understand the issue. XMC is reporting a failed archive, but the device no longer exists in XMC as I deleted it from my list of devices.
