XMC, Control, Analytics - Design Guides, redundancy
tfsnetman
Contributor
Hello,
I was wondering where I would find some design guides for XMC
so we can build a redundant setup for two sites.
  • Option 1
    • 1 x XMC VM
      • 2 x NAC Control - one on each site
      • 1 x Anaylitics
what happens when the site goes down where XMC and Analytics is hosted?
  • Option 2
    • 2 x XMC VM - one on each site
      • 1 x NAC Control
      • 1 x Anaylitics
How do you keep your XMC, Anaylitics data in sync between the two sites?
What would be your recommendation?
Thanks, Klaus
4 REPLIES 4
Tomasz
Valued Contributor II
Hi Klaus,
Yes, Extreme Access Control performs AAA functions per the configuration from the enforcement time. They are independent from XMC in sense of AAA. To reconfigure (not often to occur after deployment?) you will have to get XMC up and running.
Hope that helps,
Tomasz
tfsnetman
Contributor
Hello,
So I decided to have one XMC and added both Control engines to it.
So when the XMC goes down
  • do Control engines have all the rules from XMC applied to them?
  • would both control engines keep working (e.g. accepts radius requests)?
  • How would I manage the Control engines rules, policies, etc.
I also noticed that rules I created cannot be moved up or down (grayed out). Any idea how to fix this?
Thanks, Klaus
Ryan_Yacobucci
Hello,
The only way you can get HA with XMC is through the vmware HA feature:
https://emc.extremenetworks.com/content/oneview/ns_failover/common_ha_6.5.htm?Highlight=HA
If you had a VM host in each site you could utilize this feature.
Thanks
-Ryan
PeterK
Contributor III
XMC is not designed to work in HA ore something like that.
In your case I would suggest use option 1 extend
  • 1 central XMC with a good backup-strategy
  • 2 NACs on each site
  • 1 Analytics on each site
