XMC/NetSight connects to switch every 15 mins
Stefan_K_
Valued Contributor
Hello,
it seems that my XMC logs in to all the switches via SSH every 15 minutes.
12/30/2020 11:21:30.38 <Info:AAA.logout> Administrative account (netsight) logout from ssh (10.100.0.17)
12/30/2020 11:21:27.17 <Info:AAA.LogSsh> Msg from Master : Did password authentication for user netsight (10.100.0.17)
12/30/2020 11:21:27.17 <Info:AAA.authPass> Login passed for user netsight through ssh (10.100.0.17)
12/30/2020 11:06:31.44 <Info:AAA.logout> Administrative account (netsight) logout from ssh (10.100.0.17)
12/30/2020 11:06:28.22 <Info:AAA.LogSsh> Msg from Master : Did password authentication for user netsight (10.100.0.17)
12/30/2020 11:06:28.22 <Info:AAA.authPass> Login passed for user netsight through ssh (10.100.0.17)
12/30/2020 10:51:30.29 <Info:AAA.logout> Administrative account (netsight) logout from ssh (10.100.0.17)
12/30/2020 10:51:27.08 <Info:AAA.LogSsh> Msg from Master : Did password authentication for user netsight (10.100.0.17)
12/30/2020 10:51:27.08 <Info:AAA.authPass> Login passed for user netsight through ssh (10.100.0.17)
12/30/2020 10:36:31.33 <Info:AAA.logout> Administrative account (netsight) logout from ssh (10.100.0.17)
12/30/2020 10:36:28.11 <Info:AAA.LogSsh> Msg from Master : Did password authentication for user netsight (10.100.0.17)
12/30/2020 10:36:28.11 <Info:AAA.authPass> Login passed for user netsight through ssh (10.100.0.17)
12/30/2020 10:21:31.36 <Info:AAA.logout> Administrative account (netsight) logout from ssh (10.100.0.17)
12/30/2020 10:21:28.14 <Info:AAA.LogSsh> Msg from Master : Did password authentication for user netsight (10.100.0.17)
12/30/2020 10:21:28.14 <Info:AAA.authPass> Login passed for user netsight through ssh (10.100.0.17)
12/30/2020 10:06:30.31 <Info:AAA.logout> Administrative account (netsight) logout from ssh (10.100.0.17)
12/30/2020 10:06:27.10 <Info:AAA.LogSsh> Msg from Master : Did password authentication for user netsight (10.100.0.17)
Iā€™m not entirely sure, but I believe that it started after updating to 8.5.3.
Does someone of you guys see the same behaviour? Or do you have any idea what could cause this login?
Best regards
Stefan
1 ACCEPTED SOLUTION
Dan15
Contributor
Are you using Analytics with App Telemetry? I have discovered the same 15 min logins to all Switches with App Telemetry active. The purpose of this logins is to get the App Telemetry statistics. It works as designed. I was able to lower the frequency setting a bit to once per hour in the DB together with GTAC.
7 REPLIES 7
PeterK
Contributor III
xmc uses ssh logins for backups and fw-upload.
I think you know that, but have you checked that this isnā€™t the case?
Maybe you could set xmc logging to a higher level?
Stefan_K_
Valued Contributor
Hi Peter,
thanks for your anser!
No workflows.
Collector was my first guess also, so I disabled everything under ā€œOptions ā†’ Management Center Collectorā€. The login still happens. (And I have other installations where Collectors are enabled and I donā€™t see any logins - guess itā€™s done via SNMP.)
No way to check what triggers the login?
PeterK
Contributor III
hmm...not seen in this density yet. Could this have something to do with ā€œcollect device / port statisticsā€? Or do you have some workflows running?
Maybe, you can have a look for 900 sec timer in XMC options.
