XMC search for devices with specific VLANs
MichaelM1
New Contributor II
Is there a way inside XMC to search or run a report for all the switches in my environment that have a specific VLAN ID programmed in them?
Ex. Display all switches that have vlan 110
1 ACCEPTED SOLUTION
Ludovico_Steven
As attachment now.
10 REPLIES 10
bar
Contributor
sorry, my bad, I was just so excited to have found the fabric topology map!
This is really useful for finding L2 and L3 vsns (rather than vlans)
apologies again.
Ludovico_Steven
No! It's not Fabric Manager!
It's any XIQ-SE map, then expand the panel on the right hand side and select the VLAN tab.
You get a list of all VLANs, where you can chose the VLANs to highlight.
bar
Contributor
It's probably worth saying that to get to the view that Ludovico has posted you need Fabric Manager.
To get to the Fabric view, go to Network Devices, Sites, then Right Click on a map and choose "More Views"->"Fabric Topology"
It took me ages to find this!
Ludovico_Steven
As attachment now.
MichaelM1
New Contributor II
@Ludovico Stevens
Can you link that image or send it to me.  I cant blow it up to see the details.
Thanksā€‹
