XMC Suite8.2.9.1 64bit Endpoint Locations CSV import deletes Alias field
NinTniN
Good day Community
I'm trying to update our "Endpoint Locations" via exporting the list to a CSV, editing the file and importing the file back into XMC. Everything seems to work fine, except that all Alias data are deleted when importing.
I even tried to export to a CSV and then import the same file without editing anything and it still deleted the Alias fields. I had to manually go and add back quite a few of the Alias info as we use this to provide a clearer picture when using Purview.
1 REPLY 1
Zdeněk_Pala
did you report this issue to GTAC?
Thank you.
Regards Zdeněk Pala
