XMC TCL scripting, how to wait xx minutes between CLI commands?
‎10-03-2018 09:07 AM
As our Palo Alto firewall device has no scheduled update feature, I want to use XMC scripting for this purpose.
# request system software install version
# request restart system
These are the commands. So how can I tell XMC TCL engine to wait 30 minutes between these two commands?
Regards,
Rahman
Regards,
Rahman
23 REPLIES 23
‎10-05-2018 09:07 AM
But the first command of the script is "CLI request system software install version $version" and it is not run. For testing I deleted the "sleep" line and the result is same:
EMC User: rduran
EMC User Domain: artvin.edu.tr
CLI Login: admin
ACU-PA-3050-1 10.100.2.100 10/05/2018 02:11:20 PM at 02:11:20 PM
Error: session exceeded timeout: 30 secs
Regards,
Rahman
EMC User: rduran
CLI Login: admin
Regards,
Rahman
‎10-03-2018 11:06 AM
Hello Rahman,
never used but there is a special "sleep" command in XMC.
Open your onlinehelp of XMC and search for "How to create scrips" for more details.
On this page look for "sleep"
Have fun.
Best regards
Stephan
Have fun.
Best regards
Stephan
Regards
Stephan
Hello Stephan,
Yes, I tried and "sleep xxx" works. But my script is not working.
#@MetaDataStart
# Define your user parameters in this section. For reference, see bundled scripts.
#@VariableFieldLabel "Version"
set var version 8.x.x
#@MetaDataEnd
# Enter all CLI commands from here
CLI y
sleep 45
CLI show system info
Here is what I get when I run the script:
EMC User: rduran
CLI Login: admin
ACU-PA-3050-1 10.100.2.100 10/05/2018 01:43:04 PM at 01:43:04 PM
ACU-PA-3050-1 #sleep 45
If I don't use "CLI" keyword I get this error:
javax.script.ScriptException:
*** Script Error ***
nul
So how can I run those to commands against PANOS ssh CLI?
Regards,
Rahman
#@MetaDataStart
#@MetaDataEnd
CLI y
sleep 45
EMC User: rduran
CLI Login: admin
nul
Regards,
Rahman
Hello Rahman,
if the "sleep" command isn't working within an TCL script you can use the following TLC build in command:
after
when is the time your program waits in milliseconds.
Best regards
Stephan
after
when
Best regards
Stephan
Regards
Stephan
