XMC Wireless Management Controller Name
Stefan_K_
Valued Contributor
Hello,
in XMC Wireless Manager IdentiFi Controllers are displayed with their IP-Address and XCC Appliances are displayed as “controller”.
On the controllers itself they have a proper name configured.
This makes it hard to distinguish.
Any way to change this? So that at least the XCC Appliances are displayed with their IP-Address? Better would be to have the Name displayed.
XMC version is 8.5.0.
Best regards
Stefan
1 ACCEPTED SOLUTION
Stefan_K_
Valued Contributor
Hi Mig,
this is the same for me now. I think the restart fixed this. Well, better than nothing. 🙂
Thank you!
Stefan
7 REPLIES 7
Miguel-Angel_RO
Valued Contributor II
Stefan,
You have to delete the nickname and rediscover.
Let me know
Mig
Stefan_K_
Valued Contributor
Hi Mig,
thank for the quick reply. A nickname was already set for all the  controllers, but I set it again and did a rediscover. XCCs are now displayed with their Nickname, IdentiFi still with their IP-Address. Strange… Any idea? Otherwise this would be okay for me that way.
Best regards
Stefan
Miguel-Angel_RO
Stefan,
Do a right click on it and select Configure
Go to the tab Device Annotation and delete the nickname.
Rediscover the device and it should show the snmp name.
Mig
