AP150W transmission power 5 GHz
Tobias_Mueller
I have a problem with the transmission power of the AP150W. The transmission power is set to manual 20dBm in the AP profile, but my access points just send 13dBm on the UNII-1 channels and 15dBm on the UNII-2 and UNII-2 E channels.
Who knows how to increase the transmission power of the radios to 20dBm?
2 REPLIES 2
Tobias_Mueller
Hi Sam
The country code is 756 (Switzerland). Here is the CLI output of the command.
AP150W#show boot
boot parameters:
Device IP: 0.0.0.0
Netmask: 0.0.0.0
TFTP Server IP: 0.0.0.0
Gateway IP: 0.0.0.0
VLAN ID: 0
Native-VLAN ID: 0
Netboot Always: Disabled
Netboot: Disabled
Boot File:
Netdump: Disabled
Netdump File: 01502011110270.netdump
Region Code: EU
Country Code: 756
I've also checked the country code of an AP302W. The radio transmits 20 dBm on this model.
AP302W#show boot
boot parameters:
Device IP: 192.168.1.2
Netmask: 255.255.255.0
TFTP Server IP: 192.168.1.100
Gateway IP: 192.168.1.254
VLAN ID: 0
Native-VLAN ID: 0
Netboot: Disabled
Boot File: AP302W-MP-image-10.3r0-253000-12172020.img.S
Netdump: Disabled
Netdump File: .netdump
Region Code: World
Country Code: 756
SamPirok
Hi Tobias, the APs have to obey local regulations for wireless power levels, and that will be determined by the country code the AP is using. Could you let us know what country code you're using? You can see this by running the command "show boot-param" on the AP CLI.
