‎04-13-2021 02:11 PM
So I have an ExtremeCloudIQ account for a small environment, next to a larger Pilot environment. I know the setting to turn off the LED is unavailable in the ExtremeCloudIQ Connect portal, but it can be done over SSH. Point is, after an update from the portal the LED turns on again, overruling the SSH commands. Now first of all, I think it is kind of remarkable LEDs can't be controlled on a Connect account, since it would not be a feature corporations would move to the Pilot version for, but whatever. But is there a way to store this setting permanently so any updates from the portal would not turn these LEDs back on?
‎04-13-2021 02:34 PM
This concerns a set of AP305C access points. The setting itself is not available in the Connect version of the platform since the Management Options are not part of Connect, only Pilot (and maybe Navigator).
‎04-13-2021 02:15 PM
Which AP model?
Does this help: How To: How to disable AP LED in XIQ ? | Extreme Portal (force.com)
Best regards
Stefan
