‎03-25-2022 07:37 AM
Hi there, I am trying to enable SNMP on AP305C IPaddress: 10.1.15.158.
I am following the next manual.
How To: How to configure SNMP on ExtremeCloud IQ (XIQ) | Extreme Portal
But after passing all these steps SNMPwalk returns a timeout.
~$ snmpwalk -v 3 -On -u username -l authPriv -a MD5 -A 'password' -x DES -X 'password' -m ALL 10.1.15.158 1.3.6.1.4.1.1916
~$ snmpwalk: Timeout
Could you please advise how to make it work as expected?
‎04-06-2022 07:16 PM
‎04-06-2022 06:32 PM
‎04-06-2022 06:06 PM
Hi Roman, thanks for adding me to your XIQ instance. I reviewed your setup with Nick and the configuration looks good. We see that the SNMP configuration is reflected in the delta audit on the AP, which just means it's waiting to be pushed out. We did notice that the native VLAN in your SNMP set up is different than the native VLAN currently in use. It's possible that when you are trying to push the SNMP configuration out to your AP, it's attempting to switch to the new Native VLAN but isn't able to pass traffic on that VLAN, which would cause it to lose connectivity with the network and revert the configuration change back to what it was before the latest update push. If you could confirm that the switch ports are all configured to support the new Native VLAN, that would help.
Also, the SNMP location will be picked up from the location you assign to the AP. You can assign the AP location in the ML Insights> Network 360 Monitor page.
Hope this helps! Let us know if you need any assistance checking your ports for the new native VLAN.
‎04-06-2022 05:45 PM
‎04-06-2022 05:37 PM
