Manage > Devices > View - problem with column order and width, default view vs custom view.
w1f1n00b
Contributor II
First, I find it frustrating that on each page reload, the view reverts to default, and I have to re-select custom every time.
Is there some trick I'm missing?
Then, even if I get my custom view looking how I want, with correct column order and width, it seems to randomly re-order my columns, or adjust the widths to way to wide.
Is this just me? Is this a firefox issue? Is there some holdover in my account from previous xiq versions?
Any help or advice is appreciated.
1 ACCEPTED SOLUTION
Christoph_S
Hello @w1f1n00b,
When you select the custom view, click on the Edit icon, give it a name and save as default. This will persist it.
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000116571
BR,
Christoph S.
2 REPLIES 2
w1f1n00b
Contributor II
🙏Thanks a million!!!🙏
Christoph_S
Hello @w1f1n00b,
BR,
Christoph S.
