Manual transmit power not working
Hans
Contributor
Hello Community
We installed some new AP4000's. We use radioprofiles, however want to do some testing with different Tx power levels. When I configure the manual tx-power of an AP4000, this change is not executed and the power level is still the one configured in the radio profile. Checked by the CLI and the Tx-power of the radio profile is shown, not the Tx-power I manually configured on AP level.
1 REPLY 1
DeVoID
Valued Contributor
When i had this issue, i had to select the AP, then Actions, and Revert device back to Template Defaults (bets to clone the AP template, give it a name, and then add it to your network policy), after thats done, then try updating your power, and then a delta/full update.
Thanks, Jason.
