Extreme Control and Policy
RobertD1
Contributor II
Hello,
Does Extreme Policy work on GNS3 EXOS VM?
I see the network policy Deny Access is sent to the switch port but does not block traffic.
I will also test on a real switch but just wanted to know if it is possible or not.
Edit: I tested with a real switch and it worked!
The EXOS switch receives accept message with Deny policy. So, in End-Systems table it is green and accepted. Why is not a rejected status (red)? What if I want to be notified by email when there is a reject this will not trigger if accepted with Deny policy?
Thanks,
Rob
1 ACCEPTED SOLUTION
Stefan_K_
Valued Contributor
Hi @RobertD1
If you want to have it rejected tick "Reject Authentication Request" in the NAC Profile. Then it won't be green in the end-system table.
1 REPLY 1
Stefan_K_
Valued Contributor
Hi @RobertD1
