‎08-13-2026 08:03 AM
Hi
I need to configure the Fabric Engine Access Port and Control Policy Mapping for VOIP devices. The port should be tagged in the voice vlan and also the switch should tell the VOIP device about the tag by LLDP MED. Behind the VOIP device we need to connect end device which should be put in untagged vlan.
My switch/ radius config looks like this:
radius server host x.x.x.x key ****** used-by eapol priority 1
radius enable
radius accounting enable
radius dynamic-server client x.x.x.x secret ****** enable
radius reachability mode use-radius
auto-sense wait-interval 2
# EAP CONFIGURATION
eapol enable
# PORT CONFIGURATION
interface GigabitEthernet 1/2
auto-recover-port enable
spoof-detect enable
auto-sense enable
name "NAC"
no shutdown
slpp-guard enable
eapol multihost mac-max 8192
eapol multihost eap-mac-max 32
eapol multihost non-eap-mac-max 32
Thanks for any help or best preactice advise.
Thomas
Solved! Go to Solution.
‎08-18-2026 03:49 AM
If you configure auto-sense voice settings it will advertise the voice VLAN over LLDP-MED (assuming the phone gets identified as a phone by LLDP):
auto-sense voice i-sid 10100 c-vid 100
If using RADIUS authentication, the RADIUS reply should just be an accept in this case, and the phone should end up in the voice VLAN tagged. If you don't want to RADIUS-authenticate the phone, you can bypass RADIUS for phones using "auto-sense eapol voice lldp-auth".
Link to section in the user guide: Fabric Engine v9.3 User Guide
For the client device connected behind the phone, you can either:
‎08-18-2026 09:59 AM
Hi Thomas,
in our case its different VLANs/I-SIDs, on the same port (transparent to the devices). Here is the documentation for this: https://documentation.extremenetworks.com/VOSS/SW/90/VOSSUserGuide/GUID-385E2C11-3642-494E-8A17-1273...
Kind regards
Oli
‎08-17-2026 05:55 AM
Hi Olini
Thanks for reply, does both VOIP and Client using the same VLAN/ I-SID ID? are they both untagged?
Thanks
Thomas
Hi Thomas,
Kind regards
Oli
