Add VLAN to trunk causes switch to drop
Terren_Crider
Contributor
Hi all, I've got two switches separated by about 7 miles of fiber and an Internet link at each site. I need a certain number of VLANs to extend between the sites for HA purposes. VLANs: tagged 243, 923-925, 927, 1000, untagged 4040 All of these VLANs span the trunk no problem except for 927. When I apply 927 the distant switch drops. When I remove 927, it comes back. Spantree is applied and enabled at the HA site, but not the main site. Where do I need to look to solve this problem?
21 REPLIES 21
Jeremy_Gibbs
Contributor
Do you have spangaurd on or adminedge turned on? Also, what hardware and code are you running at each site? Also, what version. Take a look at this, depending on what you are running.
https://community.extremenetworks.com/extreme/topics/connecting-s-series-with-x450-g2-rstp-error-mul...
We may be barking up the wrong spantree here. It doesn't make much sense to me why 927 has problems, but the other six VLANs are fine.
SID Port State Role Cost Priority --- ---------- ---------------- ----------- -------- -------- 0 tg.11.1 Forwarding Designated 20000 128 0 tg.11.2 Blocking Backup 20000 128
STP Diagnostic Port Counters for SID 0 Port tg.11.1 ------------------------------------------------------------ Message Expiration Count - 0 Invalid BPDU Count - 0 Disputed BPDU Count - 2209 STP BPDU Rx Count - 0 STP BPDU Tx Count - 0 STP TCN BPDU Rx Count - 0 STP TCN BPDU Tx Count - 0 STP TC BPDU Rx Count - 0 STP TC BPDU Tx Count - 0 RST BPDU Rx Count - 2209 RST BPDU Tx Count - 0 RST TC BPDU Rx Count - 0 RST TC BPDU Tx Count - 0 MST BPDU Rx Count - 3544 MST BPDU Tx Count - 2295794 MST CIST TC BPDU Rx Count - 0 MST CIST TC BPDU Tx Count - 11 SPT BPDU Rx Count - 0 SPT BPDU Tx Count - 0 SPT TC BPDU Rx Count - 0 SPT TC BPDU Tx Count - 0
Also, another good command is, show spantree stats active
See if there is anything being blocked already etc...
