How can I block an edge port where is connected an unmanaged switch A4 EOS
Alberto_Cornejo
How can I block an edge port where is connected an unmanaged switch A4 EOS.
I means how can the port be blocked automatically if an unautorized switch is connected to an edge port.
2 REPLIES 2
StephanH
Valued Contributor III
Hello Alberto,
If you are using XMC with NAC, another way is to enable authentication on the access ports to which unauth switches maybe connected.
Regards
Stephan
Regards Stephan
PeterK
Contributor III
Enable Spanning Tree (normaly this is the default on a EOS-Switch). Set Port mode to admin-edge. And enable Span-guard.
