Issue of random recognition of SFP+ coded Extreme on the x620-10x
AIT_Support
New Contributor II
Two versions of XOS has been tested: 21.1.1.4 patch1-2 and 21.1.1.4 patch 1-5
The Same SFP connected on differents ports displays different errors messages. The interfaces are sometime functional sometime not functional, they are flapping.
The similar SFP modules are functioning on our Production environment without issue.
15 REPLIES 15
AIT_Support
New Contributor II
Hello Brandon,
The model is Flexoptix" all models => 1G T, SX, LX, EX et 10G SR, LR, ER.
Thanks you for your support.
Regards,
Lionel MOUZONG
BrandonC
Are these Extreme optics? If so, what is the model number?
From the output you provided, it looks like the switch is having trouble reading information from the optic.
AIT_Support
New Contributor II
Hi Brandon
Any help ?
regards
eva
AIT_Support
New Contributor II
Brandon
It is an non native module but coded Extreme.
Eva
AIT_Support
New Contributor II
07/05/2016 09:19:44.15 : Reading of DDMI data failed on the optical module in port 7.
07/05/2016 09:19:44.15 : summitCardPortGetTransceiverInfoSfp: Unable to read DDMI info from Transceiver for port 1:7
07/05/2016 09:19:44.15 : Optics module in port 7 is not Ddmi capable
07/05/2016 09:18:09.94 : Reading of DDMI data failed on the optical module in port 7.
07/05/2016 09:18:09.94 : summitCardPortGetTransceiverInfoSfp: Unable to read DDMI info from Transceiver for port 1:7
07/05/2016 09:18:09.94 : Optics module in port 7 is not Ddmi capable
07/05/2016 09:18:06.99 : Media SF+_UNKNOWN is inserted into Port 7
07/05/2016 09:18:04.98 : Media SF+_UNKNOWN is removed from Port 9
07/05/2016 09:17:42.76 : Reading of DDMI data failed on the optical module in port 9.
07/05/2016 09:17:42.76 : summitCardPortGetTransceiverInfoSfp: Unable to read DDMI info from Transceiver for port 1:9
07/05/2016 09:17:42.76 : Optics module in port 9 is not Ddmi capable
07/05/2016 09:17:30.15 : Media SF+_UNKNOWN is inserted into Port 9
Port : 9
Media Type : SF+_UNKNOWN (Unsupported)
Vendor Name : F3EOTI
Part Number :8_?6w2
Serial Number : AMW
Wavelength : 850 nm
Temp (Celsius) : 127.28 Status : High Alarm
Low Warn Threshold : -5.00 High Warn Threshold : 127.00
Low Alarm Threshold : 127.00 High Alarm Threshold : 127.00
Voltage AUX-1/Vcc (Volts) : 3.33 Status : High Alarm
Low Warn Threshold : 3.05 High Warn Threshold : 3.50
Low Alarm Threshold : 3.00 High Alarm Threshold : 1.61
Tx Power (dBm) : -1.96 Status : Low Warning
Low Warn Threshold : 5.15 High Warn Threshold : 0.00
Low Alarm Threshold : -9.39 High Alarm Threshold : 1.03
Rx Power (dBm) : -22.01 Status : Low Alarm
Low Warn Threshold : -12.10 High Warn Threshold : -0.00
Low Alarm Threshold : -14.55 High Alarm Threshold : 1.03
Tx Bias Current (mA): 65.15 Status : High Alarm
Low Warn Threshold : 1.68 High Warn Threshold : 65.09
Low Alarm Threshold : 1.00 High Alarm Threshold : 49.73
Port : 7
Vendor Name : FXOPOIX
Part Number : N/A
Serial Number : N/A
Wavelength : N/A
Temp (Celsius) : -- Status : N/A
Low Warn Threshold : N/A High Warn Threshold : N/A
Low Alarm Threshold : N/A High Alarm Threshold : N/A
Tx Power (dBm) : N/A Status : N/A
Rx Power (dBm) : N/A Status : N/A
Tx Bias Current (mA): N/A Status : N/A
